I would not want to haul all that weight up a hill that required the smallest chainring and biggest rear sprocket. So I think this is right. A double chainring would be fine on the front and I'd echo the need for a 52 upwards on the front. I spent a lot of time in top gear today. True off road was typically in 2nd or 3rd. On road 5th or 7th all on the 48T front.
I'm not finding it noisy at all. There's more noise from the rubbing front disk than the motor! I think I have finally understood the adjustment on the disks and got rid of the noise but actually I think I'd rather have V-Brakes.
Old Timer, what pressure do you run the tyres and are they the oem Cheng Shins?
I run 55-60 psi and that is the tyre. From memory they are puncture resistant and although I have Marathons ready to go on I`m testing them out and around my area with all the thorns and flint they are so far (touch wood) doing OK.
I did another run today to try out the 55T chainring and found In med power I was using mainly 5th and 6th. 7th would only really come in using high power.
With regards the brakes, now set up I really do find them very progressive with a good deal of feel.
With regards to range that is around what I`m finding on the supplied battery but you`ll notice from other threads I have fitted a 13Amp Li-Polymer under the crossbar for longer runs.
I really like the close ratio gears that change so sweetly ( keep imagining they are more expensive)
I was saying to another member the other day how I always switch to throttle when approaching a junction ect and then with the throttle open just pedal away and switch back over to pedelec whether I`ve let the throttle return or not and the transition is always silky smooth.
Well! I`m quite satisfied at present with 99% of the bike, the 1% was the very narrow centre stand that I have changed for a side stand(in fact because I`m often parking up on rough or softish ground and the rear is quite heavy I`ve fitted two side stands) one at the centre and one on the frame at the rear and they support the bike a treat. I keep meaning to try my wifes centre stand that is almost double the width on the feet but I think it might come close to the chain.
Dave
