LED panel question - 880 vs 810 (4wire and 5 wire)
KirstinS
3,224
899
Brighton
Hi all,
I’ve ordered a controller from PandaBikes to get me back on the road – very simple, square wave, sensorless here http://www.pandabikes-shop.co.uk/communities/9/004/012/862/389//images/4619157509.png
They sell whole kits with a LCD or a simple 880 LED panel
I ordered neither as I’ve a bunch of spare LED panels, in particular at least 2 x 810 panels which looks identical to the 880
Except – the 810 has 4 wires and the 880 has 5 wires
What is the extra wire for ?? They have exact same buttons i.e. mode, on/off and 6km
I’m thinking that the extra wire is redundant for the LED panel but used in the LCD version.
Any other ideas or anyone in the know ?
many thanks
Kirstin
trex
7,703
2,671
some LED panels have light switch function. The fifth wire will be for the lights.
The 880 doesn't have a light switch function. The 810 has four wires: 36v. 0v, 36v switched and signal. The signal gives 1v for level 1, 2v for level 2, 3v for level 3 and 4v for 6km/h.
All the LCD panels that I've seen have 5 wires. The difference is that the single analogue signal wire is replaced by two data wires: tx and rx. I've seen controllers where you have the choice of LED or LCD panels, so those LED ones must transmit data. Therefore, the 810 won't be compatible. If you've got a spare LCD panel, it'll probably work.
Reactions: KirstinS
KirstinS
3,224
899
Brighton
Ahh thanks - I guess I could try the LCD 3 I have from bms battery
Or shorting 1,2,3 and 5 ( not Tx) this works on the bms battery controllers that take LCD anyway (according to their wiring diagrams)
I have asked Panda bikes about this as well so will advise. They have been really helpful and responsive thus far
KirstinS
3,224
899
Brighton
had the following in from Panda to answer my queries - what do you reckon ?
the 880 display can have the max speed setting changed and that is what the extra wire is for. The ones we sell are unrestricted but we can configure to be restricted to 15mph if required
if you short the red and blue wired to the led panel from the controller this has the effect of making the controller always turned on so you don't need the display to turn it on
Shorting the red and blue wires doesn't always work. You can end up with strange power settings, like minimum PAS all the time and other strange results.
I would say that Panda have either given you a minimal fob-off answer or they don't understand all the functions of the LCD. What about wheel size, mph/km and other settings, but most important of all, PAS settings.
The type of controller (square or sine-wave) has no bearing on the compatibility. There's a good chance that your S-LCD3 might work on some functions. Try it and let us know, but don't forget to get the connections in the correct sequence because some of the wires carry battery voltage and others 5v data.
KirstinS
3,224
899
Brighton
I would say that Panda have either given you a minimal fob-off answer or they don't understand all the functions of the LCD. What about wheel size, mph/km and other settings, but most important of all pas
What you say Makes sense when talking about LCD
But I was asking them about the 880 led vs a 810 led and that was answer they gave
They sell this controller with either led or LCD
Anyhow I'll try things and revert back
My apologies for that, but how does that wire change the maximum speed then? It doesn't make sense to me. Changing the maximum speed requires data to be sent for which you need two wires, or are they talking about the green PAS level signal wire, which is present on the 810 panel?
Reactions: dgncsk
KirstinS
3,224
899
Brighton
So, re reading what they say, I wonder if the extra wire is redundant when using an led BUT is used to program the controller i.e. Add the 15mph restriction which they say they can do
KirstinS
3,224
899
Brighton
Panda confirm they have a gizmo which they plug into the 880 panel to set the 15mph limit if so desired. Not set in the controller itself which is interesting
It comes unrestricted unless asked for
No idea if this means a 810 panel can be hacked in to work or not
Any thoughts here ?
KirstinS
3,224
899
Brighton
Good news and bad
The LCD 3 turns on just fine (wires matched) and the PAS turns on (there is a light on theb one baldylox kindly have me)
There is 7,7 v at throttle between red and blue,. But nothing works rhe motor, nothing at phase wires
Any ideas ?
The S-LCD3 can send its data under three different protocols set in one of the C parameters. You could try the other two protocols.
KirstinS
3,224
899
Brighton
I bought a 880 panel from panda, arrived next day
The panel turns on but flashes on lowest led showing low battery
But the battery is reading 54v. At the controller it is getting 54v too
Beyond that there is voltage at pas and at throttle but neither will turn the motor. In fact there is no power at the phase wires
Even using the 6km button gets no power at phases ( but flashes to show it is working at the 880 panel)
Any ideas of the fault?
Jeez! You don't get much luck. You need to help a few more old ladies across the road.
Some of the LCDs require that you use the motor for a bit before they figure out the correct voltage. First, you should call Panda. If they can't belp. Try discharging the battery a bit, say to 48v.
Yes, but it measures the voltage in the same way. Regardless of the voltage display, you should try it with everything disconnected except the motor battery and panel. Then try shorting the throttle 5v to the signal wire to see if the motor kicks.
Reactions: KirstinS
KirstinS
3,224
899
Brighton
Tried all that to no avail
But I can be certain the issue is with the controller/panel from panda
Whilst looking for solder I found my original 8 fun, 14a 36v controller. Hooked this up and worked straight away.
Pretty gutless now but at least I'm back on road with my 36v pack !
Will take it up with panda in the morning
KirstinS
3,224
899
Brighton
Panda haveb again been super responsive. They had replied by 8.30am today and are sending a new controller and panel out without quibble
Stuff does go wrong - it's the service that makes the difference. So far I'm impressed with theirs
