Mid drive 250w speed when reprogrammed
There's some problems you might encounter with carbon fibre frames. Many have non-standard bottom brackets, so you need to make/buy adaptors to fit. Some are too thick to let the motor in, and lastly, you can't clamp the anti-rotation plate to carbon fibre or the adaptors, so you have to fabricate a different anti-rotation method, Some carbon fibre frames have moulded in aluminium bottom brackets, which should be OK.
Reactions: flik9999
