Hi Guys
I looking at the next build and would like to use a 29er or a frame up build. What is the best frame for the mid drive BBS setup .. A frame that actually fits the motor and will mount centrally with at least not too much messing about. I know it's all about bottom bracket and how the stays are attached as my carrera would need a fair bit of work to get the motor central so both crank arms are central..so I've set it up the best I can as I don't want to start bending the stays so the motor sits further inboard.. The thought was a 29er will have better rolling and gearing due to bigger wheels.
