Servicing BBSHD after a few hundred miles
arrkaye
20
37
london
Hi all,
My BBSHD feels a little sluggish when I pedal, and turning the cranks seems to produce a rubbery sound.
Is there any specific maintenance I have to do? Especially after a wet winter here in the UK?
Any advice is appreciated massively.
Thanks!
Yes. It's called a complete strip down.
Salty water has most likely got in and corroded something. You need to check.
Fordulike
3,802
1,537
Before you go through the, not so easy, procedure of a strip down. Take the chain off the chainring and turn the pedals, just to make sure it's not something else in the drivetrain that's causing the issue.
wheeliepete
2,047
755
Devon
I pulled the controller and secondary gear casing off my HD a couple of weeks ago after a winter of deep mud and snow etc. All dry and clean inside which surprised my somewhat. If your drive isn't feeling or sounding right, then it's best to investigate.
arrkaye
20
37
london
Thanks all. Will give it a go. Are there any guides anywhere demonstrating the process?
