Synergie mistral
echowind
35
According to the new brochure {electric transport shop.com} the Synergie Mistral has a brushless motor. Is this correct?
Kal
84
I've always understood that the Synergie Mistral has a brushed rear wheel motor.
30,381
I've always thought it was, but without any evidence, and have been surprised at members posting that it's a brush motor. With the low cost of Hall effect motors and controllers now, there's little point in fitting a brush motor, and they must be getting scarce and difficult to source now anyway.
echowind
35
I thought it was a brushless motor, there was a discussion about the drag/cogging, i think i will give them a call.
rooel
357
I think the idea that the Suzhou Bafang fitted to the Mistral has brushes arose from postings to the effect that it is difficult to pedal without power, some users using the word "drag", others "cogging". I was concerned about this prior to purchase but went ahead anyway. I cannot say there is much evidence of cogging, but possibly there is some drag. However, I think this arises more from the weight of the bike, rather than the brushes, if there are any. And if the battery is removed from the unpowered bike the weight is reduced by 4.6 kgs, making pedalling, albeit in lower gears, easier.
The front wheel Suzhou Bafang fitted to my Speed TR is sold by Alien Bikes as "brushless" and I have not found much difference between it and the Mistral motor when power is unavailable.
However, I am not much of an authority on all of this as I endeavour never to run out of power!
Kal
84
Would the number of wires coming out of the motor confirm which type of motor the Synergie Mistral has? I think there are only two wires and I have read that this means it's a brushed motor but I don't know if this is correct.
rooel
357
I think I read this somewhere too, but do not remember where. There are certainly only two connections to the motor, presumably the positive and negative of the power supply.
frank9755
1,228
London
If it was brushless it would be most likely to have 8 wires, so sounds like its a brushed motor.
Brushed motors are a bit noisier than brushless, but an advantage is that they typically have lower rolling resistance (cogging)
30,381
Yes, with two wires it is brushed after all.
Hall effect motors normally have either 3 or 8 wires, 3 wires for the type that has to be pedalled off the mark before the motor cuts in, 8 wires for those that drive from a standstill.
The Tongxin Nano Hall effect motor is the one exception to that, since it can drive from a standstill without the five additional wires using a different type of feedback system to the controller.
fishingpaul
871
86
I seem to remember that the cytronex nano motor, needs pedalling up to 5mph before the motor is turned on.
30,381
That's by their design choice Paul, it could drive from a standstill if they chose to design their system to use the Nano that way. They've opted for the more range economical option, rather than the Brompton way with the Nano powering off the mark.
