Woosh Camino Tyre Change
bowserman
11
I am loving my new Woosh Camino!
Looking to fit some Schwalbe Marathon Plus or E Plus tyres, as I have used Marathon plus in the past with no punctures.
Is the rear wheel removal straight forward, ie, just unplug the power cable then wheel off?
No experience of e bikes so dont want to muck anything up.
Also, will 700 x 38c fit ok as I have 700 x 42s on as supplied?
Thanks.
3,993
Yes, you can use any width you want. It's very straight-forward. take a photo of the washers and spacers on the axle so you know how they go back. Make sure the cable goes downwards (towards the ground) when you put the wheel back in. when you reconnect the motor make sure that the connector goes all the way to the marked line, otherwise you'll soon be looking for a new controller.
Related Articles
