1000W 48V Hub Conversion Kit
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
I know this is an old post but I thought i would share a picture of my 2.5 year old LiFePo4 48v 12amp battery repaired abused and pushed to destruction by my 1000w DD Ebay motor kit.
No fires or venting from the pouches has ever happened with these cells, just as well as i use a backpack.
These cells are rated as a 2c (24amp) max discharge they were being pushed to nearly 4c (40amp+) by this motor kit. but still lasted 1.5 years with this setup.
Wow incredible and reassuring to read this. And here was me worried about a little scratch on mine the other week ;-) It seems they can take a fair bit of rough handling then.
aaannndddyyy
304
9
63
Norwich Norfolk
banbury frank
Banned
Jan 13, 2011
1,565
Hi that price included delivery by DHL 2 to 4 days and they value the goods at low value so no other costs if you are lucky I forgot to put in the C rating It is 10 C
Charger from about £30
They have the wrong description the pack is made from 16 X Headway 40160S cells These are 16AH 10C cells BMS 100Amps continues WOW WOW with a good motor and controller 40 MPH
Frank
jbond
411
Ware, Herts
www.voidstar.com
aaannndddyyy
304
9
63
Norwich Norfolk
Frank
That is a good price
A 48V Battery will not push a hub motor much beyond the 30mph mark with a 700cc wheel without some modificationsImageShack Album - 14 images, high amps wound get you there fast, as a rule volt=speed amp=toque.
If your interested in moding a DD motor heres a good read Endless-sphere.com • View topic - ELECTRIC TRANSMISSION DELTA /WYE and SERIE/PAPALLEL stator
