It had to come!!
Hi all (and c elder in particular)
Back in April you did an excellent review of 2 years and 8000 miles experience of a Pro Connect. You outlined your chain cleaning/replacement regime. I reported at that time that after some 3500 miles each my wife and my Pro Connects were Ok. BUT.... There are some nasty crunches coming from the chain drive now (4000 miles covered), mine being worse that Mrs 'O', but I'm heavier. (I've tightened motor bolts/cranks/pedals and it seems to be chain related and the chain has certainly stretched a lot). It got worse today during a great New Forest ride - ended up feeling like stirring porridge!
You quoted you were using SRAM PC1 1/8" chain (from SJS). I note this comes in 114 links as a standard length - is that long enough? Our chains seem to be more like 120+ links long?
Flecc - can you point me again to your excellent manual on all things panasonic motor etc. I'm going to replace the chainwheel sprocket - I note that ours are not retained by a conventional circlip as I remembered in your photo, but it's just like a sprung clip without any means of inserting pliers - do you just prize it off then slip it back over the hub?
Mike
Mike
