2006 Ezee Torq Throttle Wire Colors
zebody
57
19
East Yorkshire
My 2006 Ezee Torq needs a new throttle.
Existing colors are red black and green, my replacement has red black & white, I have tried varius combinations with no joy.
Anyone solved a similar problem? :(
Cheers
30,855
The red and black connections should remain the same, the white, green or even yellow being common substitutes for each other.
Try again, red to red, black to black, white to green. If that doesn't work, it's possible you've damaged the new throttle's Hall sensor by connecting it wrongly.
banbury frank
Banned
Jan 13, 2011
1,565
Hi Very simple
The red is + 5 volt red to red
Black - ground black to black
other color is variable voltage any color to any color
If that don't work it is not the throttle that is the problem
Frank
zebody
57
19
East Yorkshire
Thanks chaps great sorted that, next I want to remove the battery meter as it is broken with poor wires
Now can you please tell me which wires to re connect together so as to re connect without the battery meter.
I.E red black green throttle ,not botherd about pedelec mode.
Regards Zebody
banbury frank
Banned
Jan 13, 2011
1,565
Hi
Be careful the wires are connected to the battery if you cut them off the meter Just insulate the ends with some tape and leave them DON'T Connect them together You may catch fire to your bike as there is probably no fuse In line
If not sure post some photos so we can all see the problem
Frank
zebody
57
19
East Yorkshire
Hi Frank thanks here is my wireing pic
Regards Zebody
zebody
57
19
East Yorkshire
2006 Ezee 1 wire problem
Sorry new to putting attachments.
Kind Regards
Zebody
JuicyBike
1,671
527
Derbyshire
Hi Zebody
Just out of interest, what makes you think the problem is at the throttle or charge display?
banbury frank
Banned
Jan 13, 2011
1,565
Hi is the throttle now working if so just insulate the other wires the appear to be battery meter and light switch
Try Flecc diagrams on the following links
dagnostics
torq
I am sure he would of replied to your question but is getting over an operation
Frank
zebody
57
19
East Yorkshire
Ezee Torq 1 2006
Hi Frank
My old throttle was physicaly damaged, when it returned from twist to standing it would still try to move forward and was a tad dangerous.
I put a new throttle on and it workrd fine then cut out,my battery meter has been damaged for a year or two (taped up) so I moved the wires a bit and the throtle worked again for a while,
So as as I do not really need the battery meter as I always set my odometer after a charge so I know how far it will go.
Plus the damaged and expense of buying a new one I decided to cut it out.
I am sure I read on pedelecs that it would work fine without it.:(
Kind Regards
Zebody
