A anon4 Esteemed Pedelecer May 9, 2017 574 90 32 GB Jul 26, 2018 #1 I have a hub I'm considering reusing but its on a 26" rim. I want to rebuild it as a 27.5. The current spoke length I believe is 198mm, what size would I need assuming the same lacing pattern?
anotherkiwi Esteemed Pedelecer Jan 26, 2015 7,845 5,785 The European Union Jul 26, 2018 #2 Depends on the ERD of the rim in question.
Nealh Esteemed Pedelecer Aug 7, 2014 20,274 8,267 60 West Sx RH Jul 26, 2018 #3 What hub is it or the hub flange diameter also need to know the actual rim erd other wise you/we will be playing guessing games.
Gadfly Pedelecer Mar 30, 2018 53 33 Lincolnshire Jul 27, 2018 #4 There are plenty of spoke length calculators on the web: https://www.prowheelbuilder.com/spokelengthcalculator/ https://leonard.io/edd/ https://www.wheelpro.co.uk/spokecalc/ To name but three. I tend to use the last one listed if that helps.
A anon4 Esteemed Pedelecer May 9, 2017 574 90 32 GB Jul 29, 2018 #5 Thought it would be simpler, I will use the calculator, thanks
Fat Rat Esteemed Pedelecer Jun 7, 2018 1,903 726 UK Jul 29, 2018 #6 anon4 said: Thought it would be simpler, Click to expand... No chance Reactions: anon4
Nealh Esteemed Pedelecer Aug 7, 2014 20,274 8,267 60 West Sx RH Jul 29, 2018 #7 It is only simple with the right spokes length and using the correct X pattern for the spoke length.
Blunderbuss Pedelecer Mar 11, 2018 158 22 Cambridge Jul 29, 2018 #8 Also you don't want to get the spoke-rim angle so that the spokes are bendy - here is some helpful info: https://www.wheelfanatyk.com/blog/spoke-angle/ Reactions: anon4
