27 gears on an E-bike?
Peter Thornton
104
67
Kendal
Just browsing a few sites and I come across the "Haibike Xduro Trekking Pro"
It has 27 gears, by combining a 9 speed derailleur with a three speed hub gear. It doesn't appear to be marketed in the UK. Has anyone seen one of these?
  • Disagree
Reactions: grldtnr
jhruk
318
68
I think this model used to use the Sram Dual Drive system. Unfortunately it appears Sram is ceasing production of all hub gears, including the Dual Drive.
http://www.bike-eu.com/sales-trends/nieuws/2017/2/sram-stops-remaining-internal-gear-hub-production-10129065
There was always a problem using it with crank drive motors anyway as the hub gear had limited torque capabilities and the motors often had to be de-rated to comply. It certainly wouldn’t cope with the latest high torque motors now available from Bosch, Yamaha, etc.
Trevormonty
1,135
564
18
NZ
The CX drive should have enough grunt with 9-10 spd 11-40t cassette to haul a fully load touring bike up any sealed road hill. Of course if you are serious about touring then rolhoff hub is only way to go.
The advance of rolhoff is any hill can be tackled in Eco for when battery range is critical.
5,786
The SA is pretty good. Say you have a 53-38 mounted on your Bafang, GSM whatever with a 26"wheel at cadence (80-90) that gives speed range between 8.5 km/h and 66.5 km/h with an 11-34 cassette (max recommended by SA).
grldtnr
627
288
south east Essex
Fast enough for me!
By the way ,the SA ,of old were very tough and hard wearing gears,pulled s fair few down, you have to be carefull with the pawl springs, they are very small and delicate.
jerrysimon
3,292
112
Cambridge, UK
5,786
Reactions: jerrysimon
