Hi folks, I think, well I hope I have come into the correct forum following the sticky thing!
I recently bought an S/H torq to get fit after some heart repairs I had a few years ago. The torq gives me about 20+ miles range on mixed pedal/motor use, however I do not want to get stuck on some of the hills I encounter, (usually on the way back!) so I have been contemplating a back up battery.
Having a fair bit of experience with motor vehicle electrics I reckon I need about 36 volts and a few (probably up to about 10) amps. Ni Hi batteries seem to fit the bill. As luck would have it at the time of my thoughts, the Aldi supermarket was running a promotion on Ni Hi cells, the D cell 3.5 amp variety.
After visiting two stores I managed to get 20 cells at £1.25 per cell. A 2 mt length of 40 mm grey plastic water pipe, cut into 3 pieces approx. 62 cm. accommodate each set of 10 cells quite nicely. Suitable end capping pieces are available to enable contact and pressure to clamp the cells tightly.
I have assembled one such pack; it’s a 'tube' 65 cm long and weighs 1.25 kg.
And now Liddel supermarket are running a promotion on Monday 10 th Sept.for D cells, 4.5 amps at £1.00 each, so I can get the last 10 cells!
(But I am not sure how 3.5 and 4.5 amp cells mix?)
Anyway, I am sure I can fabricate the cables and push on sockets to pick up on the power input pins and clamp the tubes together to fit on the carrier.
However I need some advice.
10 cells give a 12 volt nominal EMF (36volts for the three 'tubes') but, will the motor demand pull the voltage down to below the cut out level in the controller? If this is likely, would adding an extra cell per tube compensate for the voltage drop? Would this higher voltage (40 volts) upset the controller?
Charging; If I can pick up a 36 volt charger ( I'm sure my Li Pol one will not be suitable) will it kick out enough to service a 40 volt pack (if not I will have to do them in 4 cell batches on my little domestic ni cad charger) ?
At Liddel prices it could mean a 30 cell 4.5 amp battery could cost £30.00 plus about £8.00 to £10.00 for the plastic bits.....cheap enough, if it has the grunt to deliver 5 to 10 amps?
As an aside, would these cells be suitable to re-cell an existing battery case? Again, for use as a back up/get you home pack.
Over to you electronic experts !!! Ted
