On a supplier of conversion kits website I have seen the phrase "Brushless planetary gear DC motor with clutch/freewheel" Does the 'clutch / freewheel' mean that there is no drag with the motor turned off?
I think that you've overstated that a little. You should change it to "Some of us find ......." because many of us don't notice the drag to be anything sinificant.Basically yes, the motor is disconnected from the hubshell and wheel on the overrun. For some odd reason though, many of us find much more drag on e-bikes with these motors than on the crank drive and direct drive types.
In general all these have freewheels, the exceptions being those intended for regeneration of power.
Recharging the battery when going downhill? where can one find one of these motors?In general all these have geared hub motors have freewheels, the exceptions being those intended for regeneration of power.
Here at BionX Bionx - Intelligent Mobility? systemsRecharging the battery when going downhill? where can one find one of these motors?
You keep making sweeping statements as if they're true! I am sure that you'll find that the vast majority didn't find it to be significant. There's no doubt that it's more friction than a Panasonic because a Panasonic doesn't have a motor connected to the front wheel. The question is whether the drag is significant. I'm sure, also, that we can find examples of where the drag was higher than normal because of tight seals - or whatever - that took a while to bed in, and, naturally, anybody that had a stiff one would report it, while as the vast majority, who never noticed any significant drag, kept quiet. I have three different versions of the Bafang 250w motor, and they are all the same and the same as any other one that I've been on - no noticeable drag. Are you sure you're not remembering the old days, when they didn't have clutches?On past record I'm afraid the majority in this forum have found the drag to be significant d8veh, but of course these things are only of importance to each individual so each must try for themselves. Personally I've never found any SB motored bike to get anywhere near the freedom of running of a Panasonic powered bike, most for me being miserable to pedal without power.
That's because they are true. I've been in this forum from day one and therefore remember the drift of posting trends, and I'm merely reporting that. I'm also quoting those SB motors with freewheels, mainly due to the forum only being in existence since September 2006.You keep making sweeping statements as if they're true!
I don't understand what any of that has got to do with drag from a motor, or are you trying to suggest that my motors are special in that they can produce their own power, which overcomes the drag.That's because they are true. I've been in this forum from day one and therefore remember the drift of posting trends, and I'm merely reporting that. I'm also quoting those SB motors with freewheels, mainly due to the forum only being in existence since September 2006.
Please don't be offended by what follows without reading it through. I am not counting your experience because it is extraordinary, and I'm basing that on your reporting a 70 mile range on a 36 volt 10 Ah battery at about 5 Wh per mile with an SB motored bike as nothing out of the ordinary. You must be a very special rider to achieve that since nobody else in this forum has ever reported similar results. The norm for most with SB motors is barely half that, 30 to 35 miles, or with the larger 14 Ah batteries, up to 45 miles. These are not wild statements and I am content for you to search the forum to see all the posts I'm speaking of, also seeing all those who complain of drag.
I'm not doubting your capability to achieve that circa 5 Wh per mile, but I do question that forms good advice for those who cannot achieve anything like it. Obviously with apparently the ability to achieve twice the range ability of most in the forum, you will be far less affected by drag, but conversely those without that ability will be more affected.
I've noted you say that you are not an especially strong rider, but what you report has contradicted that. Maybe you wil remember my comments on David Henshaw of A to B magazine and his strength of riding and race successes, but he does not achieve what you do, 30 miles typically on 360 Wh and only 22 miles on one of eZee's models, all while based in fairly flat areas.
As a very strong rider your perception of a given amount of drag will be very much lower of course, I thought that was obvious.I don't understand what any of that has got to do with drag from a motor, or are you trying to suggest that my motors are special in that they can produce their own power, which overcomes the drag.
And I don't care what range you or A to B magazine get out of your bikes. On the extremely hilly Tour de Presteigne ride, most of the bikes reached well over 30 miles before they needed to change the batteries. Mine went at about 35, and the Daum made nearly the whole 50 miles on it's 9aH 36v battery - apparently.
This ride was not your average Sunday ride. It was continuously up and down long steep hills with virtually no flat bits in 50 miles so that most of the time I was pushing my motor (and myself) to the maximum. I would imagine all these riders on a normal Sunday ride would be getting a range of about 50 miles or more. You must've read the post, so you should have known that. Are you sure your not being very selective with facts again to paint a different picture than reality? It's a shame because many people on the forum respect your longevity and experience on this forum, but I find it very worrying when you state things as if they're fact when they're actually your opinion because people who don't know better will tend to believe you. I've noticed that you have done this many times in the past, but I kept quiet to avoid any conflict, but now I've said it and I'm not ashamed.And you confirm what I said about hub motors, 30 to 35 miles is typical, not your 70 miles.
