its 250w Jerrysimon. It is powerful, but I'm about 15 stone
I can't work out why these torque arms are not widely available considering their life saving benefits etc.
I agree its strange how they are not readily available here. The DIY one I linked to was on my first Ebike which had a simlar Bafang 250w motor. At the time I weighed 13 stone.
Most kit suppliers of 250w motors in the UK, don't include a torgue arm. There is mixed opinion about whether you need one on a 250w motor or not.
I took the safe root when I made one myself. If you don't fit one it is important to make sure that everything is seated in the fork dropouts properly i.e. the washers and nuts are flush against the dropout sides. I think the Bafang comes with some washers with lugs that locate in the dropouts. Some forks have raised edges around the dropouts and its easy to end up with the washes and nuts not flush against the fork sides and therefore not clamping the motor/shaft in tight.
If you look at my picture you will see the recess (common in forks with quick release wheels) I was talking about where it is easy to end up with the washer/nut not sitting flush when you tighten it up.
A small DIY torque arm like the one showed in my post, would be more than sufficient for a 250w motor.
Regards
Jerry
