Alien gents power problem
Aidytodd
Jun 19, 2009
Hi new to here and received my 1st ebike less than a week a go, have only used it the last few days and evrything seemed fine with it until tonight, had just charged the battery back up and went about a 1/2 mile up the road then all of a sudden complete power failure. Came back home and checked the voltage coming from the battery and it says 39.7v when not connected to the controller. Once i connect the controller it shows 0.5v, does anybody have an opinion on whether this is the battery has failed or if its a controller problem. Have emailed bob but havent got a reply back yet. Any advice is appreciated.
Thomas
rog_london
764
Harrow, Middlesex
Thomas
Sorry to hear that. Sounds like the battery is fine (otherwise you wouldn't be getting 39.7v) but you have a duff connection somewhere. If a quick look round and a check of all connections doesn't solve your problem, you really need to refer it back to your supplier. You shouldn't delve too deeply as it will be a warranty job at worst and any unnecessary poking about may jeopardize that.
If you don't get a timely reply do try the phone - in my experience many suppliers (not just of ebikes) haven't quite caught up with the business of reading and responding to emails in a timely manner.
Rog.
Aidytodd
Jun 19, 2009
Only wanted to check see if i was getting power from the battery which i was, other than that havent done anything and dont plan to. Was just wondering if it sounded like a battery or other fault.
Thomas
drgcb
34
The Alien 36V system (with the battery in the pannier rack) seems to suffer from battery problems. I've had the identical situation to you, with the voltage reading ok until plugged in, when it drops and won't function. This was in fact a battery issue (although I don't know exactly what).
The other thing to watch out for is the key switch mechanism failing. This has happened to me twice now (am on my third battery in a year!) and manifests itself as power cutting out going over road bumps, which can then be temporarily restored by turning the key off and on again . . . until the next bump. I have now taken the key switch completely out of the circuit.
Anyway, best to get Alien to sort it, as Rog says. They are pretty responsive by email, but the telephone number frustratingly seems to be a closely guarded secret. I had no problem getting them to send replacement batteries.
Best of luck getting it sorted.
Greg
Tubaman
28
I`ve been (and still am) really impressed with my Alien 36V kit which I purchased in January 2009.
Only problem I have had, similar to this, was when I went over a large,sharp bump which dislodged the 3-pin kettle like connection that plugs into the battery.
Very easily sorted - I hope it simply ends up with being eg. a lose cable as it`s a really decent/well thought out kit.
Aidytodd
Jun 19, 2009
Where are you measuring the voltage after connecting the controller to the battery?
At the terminals that connect the battery to the controller.
Think it is the same issue you had drgcb, have been in contact with bob from alien bikes and he also thinks its the battery, same as you, i havent a clue what it is though.
Many thanks for the responses
Thomas
The Maestro
296
Thomas
Sounds like the Battery Management System is flaking out when something is connected to it and drawing power. I've also been through 3 36V Alien batteries but when I had a problem they all seemed to read less than 25 volts but would also return to normal if left for a while and then fail again after a few miles/meters. I did hear someone say that there was a bad batch of batteries a while ago and it was sorted now but I don't think it is. I can't even be bothered returning my latest battery. He does replace the batteries the instant you send one back no questions asked, and I did use to think what amazing customer service it was from an ebay seller, but after a while its just a joke. In my opinion his 36V kits aren't worth buying unless you are a very light user and don't mind if it fails at some point. The advantages of having a purpose build locking battery/rack is outweighed by the fact that the batteries are very failure prone. Just to make this a balanced Alien review, I've never heard aything bad about his 24V kits and they are a much neater fitting than the 36V kits.
Dynamic Position
307
Thomas
Thomas,
The problem you describe might be caused by the power displayer on the handle bar. If it is possible for you to disconnect battery, disconnect the displayer then reconnect battery and test whether the bike will run. I am not familiar with your alien bike, but I have seen a circuit diagram for the 2009 Kit and it looks possible that a fault in this unit could crowbar the battery protection circuitry. I have presumed that the kit is very similar to the factory fitted version.
drgcb
34
An interesting thought, Dynamic. I'm not sure if this makes any difference, but when I had a similar fault recently it was with a much simplified circuit with the original twist throttle (the same as on the Gents' Special with the battery meter on it) removed and a simple meterless thumb throttle fitted instead. If memory serves me correctly, I don't think it's uber easy to disconnect the battery meter independently anyway. In the case of my bike, the leads for the meter were soldered in separately from the standard three wire plug connector to the throttle.
Greg
drgcb
34
Sounds like you've had a worse time than me, Maestro! At least I have a functioning battery at present, although you've got me thinking about perhaps investing in a Ping replacement. What happened with yours, if you don't mind me asking? My first was a faulty key barrel. The replacement arrived and wouldn't work at all (later found to be a poor joint between the cells). The third and final has also had the key barrel fault, but instead of sending it back (got sick of the wretched postage costs) I just took the key switch out and have a small box with an XLR socket and in-line switch instead, with the whole thing contained in a Topeak rack bag. It's been reliable for a few weeks now....he says, tempting fate....
Greg
Dynamic Position
307
Greg
I did see another diagram with the connections being inside the controller, so this could the difference between the kit version and the factory fitted version. Since the power is applied through an IEC lead, I suspect that the design has been compromised to keep costs down! IEC leads could be subject to ingress of moisture from the atmosphere, sufficient to create a low resistance path (at point where the insulation has been defective/compromised), shorting the battery temporarily, causing its protection circuits to operate until the fault is removed. In the worst case scenario the s/c will blow a protection fuse or create an o/c within the battery.
Flecc might be able to comment on the likely starting current (motor power/voltage) for your bike? He might even know what your battery protection parameter are?
If it is a standard IEC lead, it should be possible to hook up the battery to a test load e.g. 3, 12Volt car headlight lamps connected in series. If battery is okay all the lamps will light brightly (and be hot).
Testing for volts does not load the battery and the battery may still produce terminal voltage thus indicating that the battery has not suffered from an o/c.
The Maestro
296
Greg
First one was loose connection at back of the key barrel - solder had come apart so I resoldered it and it worked for about 5 months before failing completely due to an unknown problem making the voltage suddenly drop. 2nd one lasted only a couple of weeks, same problem. Third one cut out after only doing a about half a mile on it, same voltage drop problem.
drgcb
34
Something of a pattern does seem to be emerging here, not to put too much of a dampener on Thomas' new purchase. I had assumed my experience was atypical, but clearly not. My Alien experience started with the purchase of an Alien Cruiser last June, which is essentially the 36V kit on a cheap alu-framed bike with the added extra of integrated lights. So far, I have:
- been through 3 batteries, as mentioned above
- replaced the gear shifter after about a week, because it was a 7speed shifter on a 6 speed bike, and hence was useless
- had a wire from the shonky lighting circuit come loose, shorting against the frame and blowing the fuse (happened less than a month after purchase)
- had the front wheel rebuilt due to irredeemable lack of true (two months after purchase)
- replaced the utterly useless v-brakes with Shimano Deore, having nearly killed myself in the wet
- suffered random cut outs through water ingress into the twist throttle
- also cut outs due to flaky brake lever switches
- finally, gave up on the bike, stripped the electrics off and fitted it to a new Revolution Trailfinder hybrid. The battery is in a rack bag, the controller box in a Maplin plastic box behind the seat post, and a simple thumb throttle on the left bar. No brake switches. Cateye/Fenix battery powered lights not off the main battery.
When you put it all together it doesn't look great (nor has it been cheap). That said, I absolutely love my bike now and wouldn't be without it. Plus I now know the bike inside out as I've rebuilt pretty much all of it!
Greg
30,381
These experiences reflect two things, the difficulties of a small company marketing low cost kits and bikes, and the high current needs of the Suzhou Bafang motors.
Shimano have an iron grip on the cycle industry and require manufacturer orders to be specified long in advance of delivery, often in the previous season. Understandable from their point of view for scheduling production quantities, but it leads to severe shortages at times of sudden high bike demand as we've had in recent times. In turn this sometimes leads to manufacturers scouring the world for components to enable their bike production to continue when demand is unexpectedly high, often having to substitute alternative components which may not be ideal.
The second problem of the motor demands is the incompatibility of providing the best quality batteries these high powered motors need at a low bike/kit price. Lower priced and lower grade lithium batteries just aren't up to the current demands, and we've seen the problems that lithium batteries have caused in the past with even the top manufacturers. Give the Alien kit a new £395 eZee 10 Ah battery or a £514 Wisper 14 Ah battery and it will be fine of course, but that's impossible at the price of the Alien products.
A partial answer that many manufacturers adopt, Synergie, Powacycle, Panasonic and Giant for example, is to use a rather lower power motor which doesn't stress their batteries so much, though it still pays to use the best quality battery that can be afforded as the latter two do.
drgcb
34
I entirely agree, and very much admire Alien Bob's entrepreneurship and attitude towards customer service. It begs the question whether the price of the kits are a false economy for him as well. He can't have made much money out of Maestro or me. I think I'll be giving Mr Ping a shout sooner rather than later, as a result of this discussion.
cogs
90
The thread is quite damning of the 'Alien' kit, but my experience of the 36v 10 has been good so far. I've had it 10 months, and use the bike regularly, often doing 20 miles around hilly-ish terrain.
That appears to be about the limit for the battery, but I'm reasonably hefty, and have panniers to disguise things a bit. Another factor is that I've a knee disability on one side, so I probably rely on the motor more than most. The battery is the original.
Maybe I'm lucky, but 10 months of fault free e cycling isn't too bad is it?
I'd say well done Alien - BTW, I have no connection to the company.
30,381
That's good to hear cogs, and I'm sure you aren't the only one fully satisfied. The problem in this thread doesn't really reflect on Alien so much as their battery supplier. The lower grade lithium batteries are very variable in performance, some like yours performing really well while many others fail. Alien isn't alone in this, even some of the top manufacturers have suffered from it previously. As I've remarked earlier in the thread, there are more advanced high grade batteries available now which are very reliable, but they often cost as much or more than the whole Alien kit, so clearly not practical for them to use.
