Battery choice 5AH+10AH or 15AH
andyh2
297
Just waiting for info on Ping battery availability to go with Tongxin kit. I can see advantages to getting 5AH and 10AH batteries. I could have a very good range with both and if in the future I put one together for my wife I'd already have battery and for shorter journeys I could save the weight.
But what I don't know is if there is any advantage to be had by having one larger capacity battery (other than not having to change over on a longer journey). Is there anything about a larger capacity battery that makes it more capable in any way, say in 'harder' working scenarios like long hills?
Mussels
3,207
Crowborough
A larger battery may benefit from not being discharged as much, leading to a longer life.
30,849
And a larger battery can give a marginally better performance since the battery cells do not chemically tire as much when under high load as in hill climbing.
torrent99
395
36
Highgate, London
As both Flecc and Mussels have said the 15AH is probably the better option.
Here's the theory. Every battery has a rating which tells you how much current it can deliver as a proportion of its capacity.
So a "1C" 5AH battery can deliver 5amps. At 2C it delivers 10amps and so on.
A 15AH battery at 1C will deliver 15Amps.
The higher the "C" the more strain on the battery...and the shorter the life.
In addition there's the DOD (depth of discharge). Discharging a battery 100% every time will lead to a much shorter charge than discharging only 33% of the charge.
So basically if you want a battery to last a long time get a big one and charge as often as possible...
wotwozere
280
Hi
I find if you go for the big ones you can go faster but not so far.
Go for the biggy if you can.
thx
Bob
andyh2
297
Thanks all, that's helpful. Big one it is then, if the prices and exchange rate don't interfere too much.
