Hey all. I've been measuing up my frame ahead of a BBSHD purchase but I'm unsure about my numbers so could do with someone more knowledgeable checking them for me.
BB is a normal square taper 68mm item so we're all good there. What I'm concerned about is the version of BBSHD I need to clear the chain stays.
I've followed this guide: https://www.empoweredcycles.com/blogs/news/101474694-bottom-bracket-standards-and-bafang-mid-drive-motors and ascertained that I need about 10mm of offset from the BB shell to get the required 70mm of clearance to the rear.
Now, that guide says anything over 8mm and I need to go with the 73mm version of the BBSHD (which is nearly impossible to find in the UK). What I'm wondering is can the casing of the secondary reduction gears (which is the bit I'm assuming will foul the chain stay) be adjusted or ground down a little?
