Bike cutting out
Robw1uk
71
Northampton
Hi All
I have a ni-mh 24v battery pack , after the charge i go on my bike and as soon as i hit a slight hill it flashes empty , and sometimes cuts off , then i have to turn the key on and off to get it kicking back in , i originally thought it was the pack so i purchased new batteries and made an identical pack left it charging for 12 hour and tried it, the exact same problem is happening , could someone point me in the right direction to the problem ,, not sure if the charger is knackered or the control unit faulty..
thanks in advance
Rob
30,828
Yes, it's definitely the low voltage cutout operating, maybe a problem with one of the new cells you fitted. It's important that they all match, just one low one and you'll get this problem.
Robw1uk
71
Northampton
hi thanks for replying yeh checked all cells and they are the same ,the bike just lacks power even when i stand still and hold the throttle and hold the bike back a slight touch , thers just no kick in it anymore
onmebike
499
West Essex
I assume your using the same make cells as the original battery was supplied with. Different makes vary greatly in their ability to provide power.
Is it possible your original battery is nearing the end of its useful life and the new cells[if not the same] aren't up to the job? The result would be similar.
If you have access to 2 x sla batteries wired in series to test bike, it may confirm battery is not at fault and you can look elssewhere for the problem.
Robw1uk
71
Northampton
i will try to get hold of 2 x sla batteries , just another question then would sla batteries run this bike ? i allways just use the assist never throttle , ill keep you posted ..
onmebike
499
West Essex
I see no reason why not. Although deep cycle ones would be best, any should do for the sake of this test, providing their of suitable Amp rating.
onmebike
499
West Essex
theskip1
159
sm6
yes you could run it on two deep cycle sla batteries. get 10amp or higher (the higher the amps the more the range ) any sla batteries will do to test it inc. car batteries.
Robw1uk
71
Northampton
Hi
Back again i got hold of 2 12v 12ah sla batteries and made sure they were fully charged attached them and the empty light still seems come on just gently holding the bike with throttle on , and it also did cut out again , Maybe the brushless motor controller ?
thanks
