bit of a weird one this, but i had a blow out a couple of days ago, quite severe (the guy whose truck i almost ended up under said he thought someone had shot out my tyres) changed the tube (which was destroyed completely) and pumped up the new tube which promptly exploded again.
rechecked the tyre and rim, but no marks,so inflated the next tube slowly and noticed the bead was not seating properly and pushing off the rim (which ruptured the tube as it popped out the side, pumped a bit, reseated, pumped a bit, reseated and got it up to the 80psi no probs.
I did around 30 miles on it yesterday without a problem, but the ride seems very harsh, and the tyre isn't running true (the wheel is fine) I'm guessing that the blowout has ruptured the bead somehow (tyres are schwalbe big apples) and i should really replace the tyre, but any other thoughts?
on the plus side, thats the last of the cr!ppy original tubes gone
