Brain power controller
DJG
47
Pulses are more defined with 6 magnets but only started the motor once and the would not do it again. Should the motor start when it pulses 5v or 0v?
3,986
It's complicated, and different controllers do slightly different things. AFAIK, the general rule is that the CPU monitors the input for pulsing. It allows a small delay before doing anything. Typically, the motor goes after about 1/4 or 1/2 a crank rotation, so something like 1/4 to 1/2 seconds.
Has your controller got the self-learning wires? If so, did you do the self-learning procedure?
DJG
47
It has the wires which I connected together, the motor ran in reverse so I disconnected the wires and then reconnected and it ran the right way, is there more to the self learning process?
8,246
Once the self learn wires are connected and correct operation is synced one needs to switch off the bike and disconnect them to ensure the process is complete.
DJG
47
I have the motor going the right way and the throttle works but I cannot get the pas to work even though I get a pulse when the magnet passes the sensor
DJG
47
Yes disconnected learn wire and tried pedalling backwards but still no working
3,986
The only other thing i can think of is that some pedal sensors are handed, so they only work on one side of the bike. Try flipping the magnet disc, then try pedalling backwards and forwards to see if either works.
DJG
47
Ok thanks, if it doesn’t work will just use leg power and the throttle, it’s so much better than nothing working which is where I started from.
