Hello all, just wanted to let you know that the Electric Transport Shop (ETS) is expecting new kit units from China at the end of September, for their Sparticle kit with the latest Suzhou Bafang (8-Fun) motor (side cable entry instead of spindle).
It will be the 24V SWXK model, but apparently it will explicitly support small 16" wheels (this was confirmed to me by another source as well). Note: on the current data sheets from 8-Fun for the Q/SWXK model, the minimum wheel size is 26" (see various attached images below).
I assume that the motors will therefore "natively" deliver higher RPM to reach 25 km/h, and hopefully the torque won't suffer too much.
I know (from someone else's experience) that the 24V 200W motor for 26" wheels (235 RPM no load) can be "overclocked" safely at 36V (battery + controller), with some minor slipping issues with the freewheel (manageable, if rider is careful with power/torque delivery...oh, and it is possible to swap one nylon gear with a steel one, which apparently reduces risks of damage). This results in 370 RPM no-load, 25 km/h on the flat without pedaling drawing 15 A, and 17.5 A when accelerating uphill.
I am however looking forward to hearing about the new motor's "native" support for higher RPM, as feeding 36V to the 24V motor invalidates the warranty.
E-bike motor(SWXK) Manufacturer exporting direct from Jiangsu China
