Bulk charging DIY A123 LiFePO4 and Konion Li-Ion packs
NOTE this post covers DIY battery packs not commercial ready built batteries where you should use the recommended charger ONLY
As you know I have been building A123 packs using nominal 3.3V (3.6V max), 2.3Ah capacity cells for a while. I usually make these into 6s1p packs and then series them together to make a small 12s1p pack for my small flat 5.25 mile commute trip, then charging again at work.
I also now have some Li-Ion Konion cells with a nominal 3.7V (4.2V max), 1.5Ah capacity. These I have been building into 5s2p packs again then serializing them together for a 10s2p pack giving a slightly higher 3Ah pack. I also have a 10s4p pack as well.
The reason I split the pack is because I have no BMS and for easy occasional balancing use a cheap RC balance charger for the 5s and 6s split packs.
My experience with no BMS is these cells remain in balance quite well balancing the A123s after maybe every 3 months of daily use. The Konions have not gone out of balance since I built and started using them almost 6 months ago. Both these cell types are also highly stable and safe even if they get damaged.
Anyway for bulk charging (i.e. when the packs are connected together in their 10s and 12s configs) I use cheap 36V plastic block chargers.
The problem I have had was that the Li-Ion need 42V (10 * 4.2V) chargers and the A123 43.2V (12*3.6V) chargers. This means two different chargers. Also for some reason I have always used the lead acid 41/44v floating/equal point chargers for the A123 which is what was recommended when these first came out. Although this should take the A123 cells to 3.6V each in practice they often end up slightly out of balance because of it. Once used for a short bit the cells tend to come down quickly to around 3.4V and are balanced.
Anyway after reading this thread on endless-phere
Endless-sphere.com • View topic - A123 capacity vs charge voltage (and other effects)
I have tried using the Li-Ion charger on my A123 cells and carefully monitoring the current as it dropped during charging until the green light lit and it seems to actually charge them better i.e. they better balanced after charging albeit only to 3.4V/cells. According to the thread linked above you only lose about 50-60mAh and I confirmed this during my test charge.
I guess the other way round i.e. using the A123 charger to charge the Li-Ion packs would have resulted in excessive charge/cell and thus failure of cells.
This now has the advantage that I can use one type of charger for both pack types
Just thought I would post this for those of you that use the A123, 12s packs. It seems to me "so far" that for these A123, 12s packs its worth bulk charging them with a Li-Ion charger.
Jerry
Jerry
