Last year, I upgraded my chainring from a 48t to a 53t, the difference for me is enough that I now ride a gear lower than I used to, and never run out of gear in 7th. I used this handy tool to work out what effect it would have, btw.
That looks very useful and I'd seriously consider it if I didn't have a hub geared bike on order.ebikes.ca sell 9-speed freewheels that are 11-32 tooth.
This is the extreme dishing on an SB motor for a 6 speed freewheel, it would be difficult to get anywhere near enough dishing for a 9 speed. That 7 speed 11 to 30 is about as far as I would try:
- The wheel may need to be dished further, from what SJS Cycles told me I don't think it will be easy or cheap with my SB motor.
Mapmanold timer,
What speed do you get from your alien kit, on full throttle on the flat.
thanks.
mapman.
Well! I measured the rear gear block on the Evans 6 speed and the width is the same as the Powertrek that is using the Shimano indexed gear change. So I wired up the Shimano Tourney indexed gear shift on the end of the bars , pulled the bike up on my pulley and with a bit of cable adjustment all the gears seem to change nicely and the chain sits in the middle of each cog. So now I can put the Wuxing brake lever on the right and position the gear change lever in a better position for when using the throttleThe large chainring on the Evans(Shimano Exage) is a 48 and the top gear is a 13 and that does seem to make a big difference over my Powertrek 48-14
I`ve been doing a few tweeks to the Evans/Alien, nice narrow saddle. I think I`ve found the rattle! it`s the battery in the carrier so(I don`t take the battery out for charging) I`ll make up some rubber strips and cushion the rattle.
Can I just say that anyone thinking of an Alien 36V kit going onto a half decent MTB will be over the moon at the speed you can punch this thing along at with throttle control.
Q. I`m gonna fit the r/h brake lever anyway now because the existing Exage gear change lever is(although indexed) is a pain, it`s push and pull and because it`s attached to the Exage brake lever I have to take my hand off of the throttle to change gear.
I have a spare indexed Shimano Tourney gear change lever (same as my Powertrek) that will tuck in nicely next to the thinner Wuxing brake lever and give me total control with my thumb. Will the indexing still work OK do you think? Tourney Lever working 20 year old shimano Exage 6 speed?
The forecasters will be pleased, they got that dead on for your area. Hopefully they will be right again and it won't be too extensive or last long, though saying it will stay cold.And BTW it`s snowing hard again here and the road is covered
Were you unable to remove the chainring from the old cranks? The new one looks like BCD 110 so it will be easier to get cheap replacement chainrings when that one wears, I've found that cheaper ones don't last as long as they should. When I replaced chainring and freewheel together the chairing wore out first, it ended up so worn that the pedals would spin but the chain just slipped over the top of the teeth.Couldn`t find anything larger with a tappered square drive fitting than a 52 tooth for a decent price so went for this one that is a double. Won`t be using the small ring so as soon as I can get some new spider screws I`ll remove it. Couldn`t try it out because of the ice but hopeful for today (sunday) cost £25 delivered complete with crank arms. All seems to line up OK.
Image New 52 tooth chain ring and crank arms on Powertrek Dynamo photo - david chilvers photos at pbase.com
Dave
The existing chain ring crank set was an all in one so no option to change it. These new rings are steel with ali arms and spider.Were you unable to remove the chainring from the old cranks? The new one looks like BCD 110 so it will be easier to get cheap replacement chainrings when that one wears, I've found that cheaper ones don't last as long as they should. When I replaced chainring and freewheel together the chairing wore out first, it ended up so worn that the pedals would spin but the chain just slipped over the top of the teeth.
It depends a lot on chain maintenance and wear, I got about 4000 miles out of my first chainring but more out of the next one as I've paid more attention to the chain and oiled it every day when there is salt on the road.The existing chain ring crank set was an all in one so no option to change it. These new rings are steel with ali arms and spider.
What do you reckon to get mileage wise out of a general cheapish chainring?
BobI'm glad to hear your upgrade was successful, this is similar to the fine tuning I have done on some of my own machines. The difference may be small in theory, but in rideability terms the improvement is quite large.
I was particularly interested in the way you use your gears. When riding my Wisper 905 which has a 14T-52T seventh gear, I tend to stay in sixth when riding on crowded cycleways with the speed restriction on. I have always thought of the seventh gear as an overdrive top, to be used in conjunction with the off-road switch. When the way is clear, with the afterburners on, it's time to snick into seventh and enjoy some speed!. The Wisper 905 is quite capable of maintaining a steady 19 mph on the flat, the high road gearing means the cadence at this speed is still manageable. Unfortunately, not all manufactures take the trouble to match road gearing to the motor controllers characteristics in this way. Fortunately, there is a plentiful selection of combinations available to us as you have found.
Your views on the 'granny-gear' are also shared by me, long before I reach that gear, I'm off it and walking alongside with the machine pulling itself up on the throttle. It also presents an opportunity to indulge in my other addiction, I spark one up and enjoy the scenery.
The days are now noticeably increasing in length, and plans are being made for some nice half day rides starting late Spring early Summer. New local rides are becoming difficult to find, so this year I will be bunging the bike into the car, and driving to some popular trails in other parts of the country. Two ideas at the moment: Barnstaple - Bideford - Barnstaple on the Tarka Trail, and Rutland Water, both rides of around 22 miles and easily achieved on a single battery for most E-bikes. Roll on !!.
I will notify the forum of any planned rides, but, as the enjoyment of any ride is dependant on the weather, it will not be possible to give more than three or four days notice, it's just impossible to forecast the weather any further ahead than that. Even then, it will have to be better than 75% probability.
All the best
Bob
Hiya again BobI'm glad to hear your upgrade was successful, this is similar to the fine tuning I have done on some of my own machines. The difference may be small in theory, but in rideability terms the improvement is quite large.
All the best
Bob
