Charger
gazza19
218
Hi does anyone know what charger would fit this it’s a electrobike by asbikes.co.uk
8,797
We need a pic of the battery charging port if help is needed.
Reactions: gazza19
8,797
The pic is very poor and the pixelling gets a a lot worse when enlarged, I can see it's 3 pin but can't see other detail which isn't clear at all. Some have a keyway notch/lug so one can't connected incorrectly.
Also what voltage ?
8,797
8,797
I don't do facethingy so can't help any more.
8,797
I'm not 100% sure but it looks very similar to a an XLR connection.
It appears to look like an XLR connection but unusually has the male pin out on the battery, they mostly have the female socket on the battery. Whether you can find a charger with a female XLR I don't know.
If it is XLR then one can but the female connector for a £3 - £4 to see if it fits and if so buy a charger with male XLR and swap the connector over to the female one.
The XLR has a small key way so one can't connect incorrectly and to prevent twisting and bending of the pins.
8,797
8,797
On both sides the Blue is signal, Red is 5v and Black & Yellow are the Gnd.
It is common to see Yellow used for Gnd if Black isn't present, if Black and Yellow appear on the same side then Yellow is the signal.
gazza19
218
thank you neath so its red to red blue to blue and yellow to black is that right pal
8,797
Yes, unless the maker/producer has totally lost the plot.
gazza19
218
Thank for your help once again pal
Hi neath I’ve fitted the pas with the colours fitted like you said but I have a slight problem the motor also turns when you peddle backwards any ideas as to why this is happening tried to send you videos but not letting me
8,797
Some PAS do that.
What controller are you using ?
