Charger
8,797
That's the display (LED) not the controller, any how it matters not as with that one can't make parameter changes.
gazza19
218
doh me lol misread it lol so what would you suggest another pedal assist if so how would i know if its a dual halled one or not as i would want a dual halled one
8,797
Just type in dual hall in the title of your search.
gazza19
218
Ive never had this happen to me before with pedal assist sensors even when I have put it on non drive side could it be because I have not put electric cut of brake levers on and there are only normal brake levers on why would I need a dual hall sensor on it tho?
8,797
Then cheapo single hall ones can't tell fwd's from backwards.
gazza19
218
Will that solve the problem then neath pal if I buy a dual hall sensor? And thank you so much for helping me with this problem as you have done with all the other ones
8,797
It might, depends on how good the controller software is.
Otherwise if worried about accidental activation leave the PAS in 0 or if it occurs because of pushing the bike backwards turn the display off.
gazza19
218
Otherwise is worried about accidental activation leave the PAS in 0 or if it occurs because of pushing the bike backwards turn the display off.
The bike only has pedal assist pal dosnt have throttle
8,797
I didn't mention a throttle ?
Reactions: gazza19
gazza19
218
Hi neath this is the bike I’m converting to an electric one and this is the bottom bracket can you suggest a dual hall sensor that will fit onto it please bought a five magnet sensor wasn’t a dual hall one and it still turned the motor on when the pedals were turned backwards as well as forwards must be a male connector
8,797
It isn't guaranteed that DH PAS will correct the issue, the quality of the controller firmware/programming may not lend it self to helping.
I noticed you are using a 12 pole disc, I had issues using 12 poles once so always opt for 8 or 10 pole which works.
Reactions: gazza19
8,797
Reactions: gazza19
gazza19
218
i have also tried a 5 pole disc and still does the same thing its starting to blag my head now lol as ive never had any issues before when ive had to change controllers
gazza19
218
Hi everyone this is the original controller that I got with the wheel for the project bike I’m converting the wire that you can see without the connector are for the display and the red and black are obv the power my question is do they have to be connected to a display or is there anyway of bypassing it
8,797
The display can be omitted in most cases but you will only get one power level, likely low power.
Check that the blue has voltage when tested against the GND wire, once confirmed one can short Blue to Red and the motor should operate. If not then also try shorting Black to Yellow leaving the 5th wire isolated.
gazza19
218
Thank you neath I’m just trying to solve the problem with the motor engaging when the pedals are turned backwards as well as forwards thats why I’m thinking it could be the controller even tho it’s brand new as I’ve tried about five pedal assist sensors now and still doing it or could you recommend a cheap controller that will do the job as I only need to connect the motor phase and halls connectors and pedal assist connector which is the female black connector one that has a bit of speed to it lol and not just low level or would a throttle work but it would have to go on left hand side because of the twist grip gear shifter thanks for any advice
