Help! Cheap eBay batteries?
Lj123
Oct 20, 2019
I plan to build an ebike soon using a generic hub motor kit, I would like to keep it on the budget side and I am fairly smart when it comes to electronics so I thought building my own battery pack from 18650s seemed like a good idea however I stumbled across these battery packs on eBay:
They are only £25 for 20ah @ 12v so for 4 of them in series a 48v 20ah battery pack it would only cost £100!
Obviously I’m skeptical but I can’t find much about them in terms of use with ebikes on the internet so I came here to ask, i can’t seem to find any continuous output values on the product page either so it may be that.
Any answers would be appreciated (this is my first post here) thanks!
2,675
CCTV camera use would be designed for very low output power. The cells would probably quickly die under e-bike use.
Lj123
Oct 20, 2019
Thanks for the reply!
Yeah I assumed it would be to do with the output power, suppose it’s back to the 18650s!
3,986
According to their size, they must be 4S3P configuration. That means that 3 or them would make 12S4P configuration, which is 44v, not 36v. Therefore, you need a motor controller that is able to be configured for 37v low voltage cut-off. A 36v controller will have it at 31V, which is too low for 12S. Also, intermediate voltage batteries, like 44v, can confuse some controllers because they try to guess that it's either 36v or 48v and adjust their settings accordingly.
The next problem is that it doesn't look like there's a BMS. If there is one, it won't be able to deal with typical ebike currents, so at the very least, you'd have to strip them down and wire in a proper BMS.
Finally, you've no idea what cells are in them. They might even be recycled cells. Even if you were able to make a battery out of them, it would most likely be very saggy and not have anywhere near the 20Ah they say.
The most important thing is that you need a battery appropriate for your needs. Don't think that you can knock up some cheap thing then ride around at 30 mph with your 1000w Voilamart kit. Cheap batteries are fine if you just want a bit of assistance and don't weigh too much.
First decide what you want your ebike to do, then choose a motor that has the right characteristics for those, then choose a controller that will provide the right amount of power to meet your needs, and finally a battery that can provide the power that the controller demands. It's all about power, not voltage. Power =voltage x current.
Fordulike
3,802
1,537
Reactions: Parsons
Lj123
Oct 20, 2019
Thanks for all the replies, I’ll make a custom pack from some new LG or Panasonic cells and a 13s bms, seems like the best bang for my buck. Didn’t think I could trust these anyway just checking to see if anyone would have had any success with them.
