Converting bike with rollerbrakes
erik_bp
Feb 14, 2015
Hi,
I'm in the situation that I finally want to make the jump into the (hopefully)wonderful world of electric bikes. I want to convert my existing bike, which has Shimano roller brakes. I've been looking at the following three motors:
https://bmsbattery.com/ebike-kit/437-q85-36v250w-roller-brake-front-driving-hub-motor-ebike-kit.html
http://www.8funmotor.com/product.asp?id=1
http://www.elifebike.com/peng/iview.asp?KeyID=dtpic-2011-92-K47B.8RWSV
Does any of you guys have any experience with mentioned motors and would you recommend either of them? Also I took some measurements of my bike and I'm pretty sure that the motors should fit, do you agree?:
Total spacing: 105mm.
I'm also considering buying the following:
https://bmsbattery.com/ebike-kit/546-s06s-250w-torque-simulation-sine-wave-controller-ebike-kit.html?search_query=torque+simulation&results=15
https://bmsbattery.com/ebike-parts/504-pas-pulse-padel-assistant-sensor-with-12-pcs-magnets-parts.html
https://bmsbattery.com/ebike-kit/670-s-lcd3-lcd-meter-for-s-series-controlers-ebike-kit.html
https://bmsbattery.com/ebike-parts/52-brake-grip-parts.html
Do I need anything else, except for a battery?
Best regards,
Erik
Why don't you fit a rear or mid motor? What bike is it?
erik_bp
Feb 14, 2015
It is a MBK Concept:
http://mbk-cykler.dk/portfolio-item/concept-7-3/
I'm not sure if the frame is made by MBK or if it is some kind of generic frame. The bike has 7 internal gears and that is why I don't want a rear hub motor. Regarding mid drive motors, I have been considering the Bafang BBS02. Technically is seems like a good solution, but due to my vanity I prefer a front hub motor.
Are you aware of any mid drive motors, which are more discrete but not crazy expensive like the Vivax Assist:
http://www.vivax-assist.com/en/produkte/vivax-assist-4-0/vivax-assist_4-0.html
Rather than mess about with drum brakes, another option would be to get some better disc brake used forks from Ebay or wherever and then you can choose whatever motor you want.
erik_bp
Feb 14, 2015
For time being I would like to keep the standard fork and fiddle with the roller brakes as a consequence. I have definitely noted your advice. If I get hooked on electric bikes, I think that I will invest in a new bike where a rear hub motor and disc brakes is an option.
How about the extra parts I have selected? Are they fine or do i need something extra?
Hi Erik,
i have a Motor for rollerbrake in my home.
Its new and unused for 100mm forks with rollerbrake and the weigth is 2kg
Diameter for the spokes is 120mm
It has 36v 250watt
Brand is shengyi:
http://www.syimotor.com/products_detail/&productId=81a09d70-96ba-49b5-8a34-48e76ac5020e.html
if you want you can have it for 80Euro but no waranty and no take back
shipping would be 15euro
I bought this motor last year in china for my selfinterest but I lost the interest on that motor and brought him to basement ;-)
