Could this be the way to go?
Gepida uk
75
Very interesting? 3000 cycles, is it too good to be true?:rolleyes:
Morag
225
Shropshire
I think those are what GoPed were talking about using in their new models in the not to far future. Not that that bit of into is of much use so I'll slink back into my corner :eek:
30,381
3000 cycles is perfectly possible for a lithium-iron phosphate (LiFePO4) battery, if the discharge rate is held at a reasonable level well within the battery's capabilities.
The snag is that many of our e-bikes don't do that, and the territory can make it impossible.
For example, a low powered bike like the Powacycle Salisbury used in the fairly flat Eastern Counties could achieve that and even more easily, especially with a strong rider.
By contrast, a weaker rider on the powerful eZee Forza in a very hilly area would have no chance of achieving that and would have to test the validity of their warranty.
Old Timer
1,279
12
onmebike
499
West Essex
How much are they then?
This is the quotation I received.
Reference: LiFeBATT Quotation 24th February 2010
To supply the following
Quantity 1
XPS1E – 3610CB
LiFeBATT Lithium Iron Phosphate 36V 10Ah Module c/w BMS System £575.00
Quantity 1 LB143360C-N 36V/8A Charger for LiFeBATT Module £125.00
eddieo
Banned
Jul 7, 2008
5,070
What bike uses these? I am sure I saw this type of battery on a bike recently....
30,381
Far too expensive. With LiFePO4 that 10 Ah battery is inadequate for most 36 volt e-bikes, most need 15 or 20 Ah with this type to preserve the long life capability.
I've looked at the claims and have to say they are really little or no better than those for the Ping batteries which are much cheaper and include the charger. 1500 charges and 3000 in favourable circumstances are no different from Ping's.
The warranty has the usual "abuse" get out clause and no doubt the high discharge rates of many e-bikes would be ruled as abuse. Since some members have Ping's batteries running well at over 18 months now with no range loss, probably safer and cheaper to stick to the known product.
Old Timer
1,279
12
Quantity 1
XPS1E – 3610CB
Bloddy hell, i could buy another e bike for that:D
30,381
Only private users. Sun issued some bike models using tiny versions of these batteries over a year ago but they soon disappeared from the market. eZee have just introduced an add-on version of this type for running in parallel with the existing battery.
onmebike
499
West Essex
The only advantage I can see is that an indivual cell can be replaced if need be and that the supplier is in the UK.
30,381
True. The high price probably results from the UK source though, an extra profit margin and import and business costs.
30,381
There is a nervousness in the industry with home re-celling or construction where lithium batteries are concerned. The accident potential is thought to be quite high, taking into consideration the needs for a BMS with careful cell management. It's rather different from re-celling NiMh.
winterdog
168
It makes me smile that the TTXGP looks like its just battery wheels and a washing machine motor :)
