I have been given a TBK-74AD 36V 250W Motor wheel for a Brompton, it was faulty. Rather than rotate, it just stutters.
Even if the motor is not fixable, I have a spare rim and spokes.
I took the motor out of the hub and the fault seems clear, at the point the wires feed from the central black disk the insulation on the wires is damadged, see bit circled in red. It looks like the wires were crossed, not laid flat, when the black disk was secured.
And the motor does respond normally when the black disk is loosened a bit.
Can the motor be taken appart to replace the damadged wires, or is it a re-cycling centre vist ?
