All the information about tyres, tubes and rims here:
http://www.schwalbe.co.uk/_webedit/uploaded-files/All Files/Technical Info.pdf
Thanks, very interesting reading! Answered a lot of things I always wondered about and makes choosing a tyre a lot easier. Even some tips for fittingAll the information about tyres, tubes and rims here:
Thanks I'll have a look for the Kenda inners.. do you have anything good/bad to say about the Brompton tyres? I've seen those are available (green and yellow label versions)..these tend to get favourable reviews but they seem very pricey and not sure of the weight and what puncture protection they have, if any.I think you will find Schwalbe Inner tube AV4's are too big a wheel diameter for a Brompton, while the AV3's are a better fit but are meant for wider tyres - that is why I use the Kenda's.
p.s. do you still have any thumb throttles available?
Ummm....ErrrrrrI tend to ride on gravel and dirt tracks a bit in the summer and didn't want to risk Kojacks
I think these will be fine.. I've got the Marathon Plus road slicks with thinner width than normal MTB tyres on my 26" which have even less tread than these 16" and even they're ok on the same gravel tracks I use..not as good as the original knobbly MTB tyres, but ok for occasional use on loose gravel tracks.Ummm....Errrrrr
Hate to say it ... but
Are you sure that the tread pattern of the 'touring' is going to help on gravel & dirt ?
I'd prefer something with a bit more bite
Indeed Alex! You can end up with something very different from what you envisioned from the start! And also well over budget if you keep ordering the wrong things or making mistakes ;-)It's easy to get waylaid from your concept goals with so many options available and the draw of getting 'more oomph' or range for very little extra cost. Getting the balance right between range and performance versus weight and looks is really hard.
8-pin DIN chassis sockets are very easy to get and cheap :
Mini-DIN Chassis Sockets : DIN & Mini-Din Connectors : Maplin Electronics
You can get PCB mount versions too.![]()
you might be better using a step-drill or cone-drill on that plastic box, Paul: They are less aggressive than normal 2-flute drills.
And the best of luck soldering to those mini-din sockets, if they are as fiddly as mini-xlr!
