Fitting a whoosh conversion kit to a Thorn Raven
SafetyThird
26
18
On the 'Endless Sphere' web-site, torque arms have been / are discussed to quite a depth. If you want to gain additional knowledge, have a look at these threads:
Thanks @Jodel ill have a read through
17,398
The motor connector isn't in far enough.
well spotted.
It needs to be pushed in about 3 more millimeters, until the lip of the top connector reaches the circle line on the bottom connector.
8,827
What are the pair of pinks for ?
SafetyThird
26
18
The other wheel I have has a Son dynohub. One of the cables powers the Dynamo lights, the other powers the PowerBug USB charger to charge up a power pack or my phone.
4,162
You know that there's no difference between a dynamo and a motor? All you have to do is connect a battery and it'll spin the wheel - extra power if you need it. If you use a regen controller, you can use it to charge the battery for the lights or power the bike.
SafetyThird
26
18
Yes but the son dynohub only outputs a few watts so would make a rubbish motor I think.
I’d like to get a USB output adapter for the big battery as powering a phone for the day for navigation wouldcause minimal drain on a battery this size.
Raboa
921
319
53
This is the adapter I used to fit my battery.
