Is it OK to dispense with the axle (spacer?) nut as shown in photo below.
The reason I ask is because I am thinking of fitting a mxus xf07 front hub to an older bike with steel forks but it is a tight squeeze. The bike has V brakes and it would be a more comfortable fit (no need to spring forks wider) if I dispensed with the 6 disk brake screws and spacer and also the axle (spacer?) nut. The wheel would need a little re-dishing (reduction of offset)
