I just thought I`d give it a separate post
The Giant Suede in the UK is Pedlec only. The sensor wires coming off the crank sensor can be shorted by a throttle or push button on the handlebar.
Intercept and tee into the two wires coming from the pedal sensor. Don`t cut them- just tee into them. Run the tee wires up to your handlebars and install a switch that closes on push.
To get to all this wiring and the controller area, you need a long cross head screwdriver in order to loosen the plastic carapace below the battery.
The sensor wires are thin, but they are the only wires coming from the crank.. I have not investigated further but it seems as if the bike controller detects whether the crank sensor is there or not. Leave it in circuit and just short the circuit with a switch or throttle.
You get power on demand on the switch with the pedelec function still working as normal.. If you use the switch loads, then your range drops
I would have chopped in the Suede by now if I hadn`t put this modification in. Pedelec is a rubbish concept in my commute. Every ebike should have a throttle.
