![](http://fotos.subefotos.com/6ac9013651c5acf085de50926b8a929co.jpg)
do you mean your power connector on the KU123 side has 3 wires? then the small wire is for the ignition switch. You don't need to use the small wire from the power connector if you have an LCD.
The LCD will connect the red and blue internally when you switch the LCD on. Without the LCD, you connect the small wire to the 36V red wire on the power connector to turn on the controller.
