Hi and my first ebike 50+
breadpud
19
Hello,
after years of commuting to work on a bike, I'm looking at getting my first ebike under my cycle to work scheme. My budget is upto 1500.
So far I'm looking at a Wisper 705 or coming to a dealer in the scheme in May 2022 is some Ezego commuter bikes, which I like the look of more so.
I'm not too fussed about range or hub motor power. However I'm on the techy side, so I'm interested in hub motor reliability. I'm also interested in the build quality of these sub 1500 ebikes and their long term dependability and parts availability. I'm just used to riding a dependable branded bike.
2,674
Things are a bit backwards in e-bikes. Many of the branded ones are reliable in the short to medium term, but because they use proprietary electrics any repairs or battery replacement are absurdly expensive. Almost nothing can be done as a DIY job.
Bikes up to £1500 mostly use fairly generic Chinese components. Dependability is pretty much as good, and parts availability better. In particular, compatibility between parts is much better so even if you can't find a direct replacement it should be easy to find something that will work. Wisper (that you mention) and Woosh provide sensible bikes at sensible prices, and excellent after-sales service.
Reactions: breadpud
8,230
Hubs motors are bullet proof usually, some folks have issues with hall sensors failing but I have not yet suffered so for the several years of ownership. The only issue I have had are noisy sealed bearings wear but a half hours maintenance and one can easily replace them for a few ££'s.
Reactions: breadpud
lightning
258
73
l've just bought a Mirider folding ebike and it's really good, surprisingly comfortable ride and weighs only 17kg
Worth a look
Even thrashing it l can get 15-20 miles from a charge, and being U.K. based at least there's some comeback if you need spares or a repair.
Reactions: breadpud
DiggyGun
134
57
England
Hello,
Mrs DG has a Wisper 705 and it is a great bike. Nothing seems to stop it going anywhere.
Stanebike
On your quality of ebikes concern, 'Which' tested folding ebikes last October and the Wisper 806SE scored 63%, the Raleigh Evo scored 64%. So Wisper appears on par with Raleigh. The Raleigh electrics are proprietary as sjpt pointed out thus the Wisper would be easier to repair when out of warranty.
I personally have a Raleigh Motus and I’m very happy with is so no anti Raleigh bias. I also looked at the Wisper 705 but preferred the Raleigh dealer I eventually purchased from. So I choose a dealer rather than a make of bike.
Reactions: breadpud
lightning
258
73
That Wisper 705 looks a nice bike, the larger wheels will always be a good thing.
It's not a folding bike so unless you need it to fold, it looks like a good buy.
The only thing l would say, is that if you don't need a folding bike it's close to the price of a bike with the mid mounted Bosch motor which is a much better system than a rear hub motor.
2,674
Just to say we too have a Raleigh Motus with which we are very happy; just slightly concerned what we will do if (when?) we do have an issue.
We bought it 2nd hand a few years ago before we realised the proprietary implications. We wanted hub gears, and that really limited our choice.
6,319
well if you ever get a motor problem peter can sort it if he has the parts, i will be sending in my old performance motor so keeps another bosch powerd bike from the scrap heap as just needs a bearing service and lasted me 7 years with a dongle and never had a motor problem. :p
8,230
Personal choice over a closed system mid drive where in the long run a hub motor will be more reliable and cheaper to repair motor should it go wrong.
Closed system bike go against EU law for easy long term repair and maintenance and some how the like of bosh etc are getting away with flouting the laws.
6,319
but we can overclock the washing machine even if it has a bosch motor :p
8,230
One goes on the German forum often and though there is a lot of propriety mid drives on there, they also have I would say more diy posts regarding hubs and kit mis drives on there. So even the Eric's don't rate the likes of bosh that highly as the market for kits over there is massive.
Like SW a lot also don't give two hoots about speed and power.
lightning
258
73
Good points.
I was talking more about the actual riding of the bike, rather than how easy it is to repair.
l do take the point about repairs though. l've got both, although my mid drive is a Shimano, and there are no spares for the motor at all, so if it fails l am faced with a bill of nearly £1,000 to replace the motor.
My hub drive bike isn't as good a system, although it's okay, but it's cheap and easy to repair.
Unfortunately however, hub drive doesn't really work for mountain bikes.
8,230
Not for proper serious fast mtb riding, but more then capable for all other exploring /riding though. I use a 700c Boardman Mx with a hub for all my off road adventures on the S/Downs & N/Downs, on the S/D I count on one hand the bikes I see using the more obscure trail routes I use. Most riders I see up there tend to stick to the main SDW.
I visit Chattri as it is nice restful spot and a shrine for the Indian faiths killed during the great war, I see a some folks who walk there but never another ebiker.
I expect as my visits are weekdays I miss the weekenders who drive there, I cycle the 20 odd miles there and back as well as the 30 - 40 mile route I ride whilst up there.
What makes a hub is the electronic kit used with it, current used and the motor winding. No use having a high wound motor one needs a low wound one for torque.
breadpud
19
Ah good. I'm on the right lines with my budget it seems then. I like your response. Thanks.
lightning
258
73
Yes l accept it's only for serious MTB riding where you are going to need the gearing/control of a mid drive motor.
For trail riding and light off road, a hub drive will provide plenty of good clean fun.
