Hub Motor rattling - not a lot but annoying
carlbikekits
43
Hi pedelecs,
Anyone with experience of hub motor noise?
It sounds like a consistent but relatively quiet rattle. I've removed the motor out and the gear cogs could be more flush. There is a 2-3mm gap near the circlip which allows the gearing to give across the axle a little. See image attached. I'm wondering if that could be doing it?
Will a thicker circlip do the trick?
Your thoughts appreciated, as always.
Best wishes
Benjahmin
2,484
1,696
69
West Wales
You're not going to believe this, but have a look anyway.
Hub motors can make a real mechanical sounding noise, even with vibration coming through the handle bars on a front hub, when their electrical connections are poor.
Told you you wouldn't believe it.
Have a look at ant connectors on the phase cables to the motor. There is generally a connector near the motor. Look for any signs of heat damage or corrosion that could cause a resistive connection. Bullet connectors are particularly prone to this.
I replaced mine with MT30 connectors. Got rid of a really nasty sounding rattle and vibration.
