I. INTRODUCTION
Electric bicycle torque intelligent sensor (known as PAS\ torque sensor\1:1 power-assisted). It is a high-tech component designed for electric bicycle with ergonomics. It has superiority to match well with all electric bicycles available in the market. It employs the dual-magnetic loop - Hall elastic angle difference to detect the dynamic torque, which is converted to DC signal and sent to the controller.
II. FUNCTIONS AND ADVANTAGES
1. High universality: Applicable to brush / brushless, high / low speed controller - electrical system, 24V/36V power system; apply to ordinary bicycle D-type models.
2. Facility to install: Install as the normal chain wheel crank in every size.
3. Assistant power adjusting function: It has five assistant power level and the battery will be displayed on a dashboard.
4. Riding on comfortably: Large linear torque range with great stability and you will feel more soft when the gear changes.
5. Prolong battery life-span: Half of the output power can avoid the damage of the high-power output bring on the battery. Also the product can reduce the power automatically when the speed is increasing. At the same time, the mileage can be increased twice or more.
6. Good security: Good operation security sensor can control the speed very well and the electric power can be turned off in 1s after the pedal stopped.
7. Well acclimatization: it has excellent anti-jamming ability that can work as normal in dirty water.
8. Speed limitation: The vehicle can set a maximum speed transmission ratio (such as: 25 km / h power cut)
9. Our controller use the method of voltage and current dual control, so it can save more battery, smoother, lower noise, lessen vol., dormancy function. It is your ideal choice. (Size: 84x55x25mm)
苏州捷诚科技有限公司
Suzhou Victory Sincerity Co., Ltd
Tel: 0086-512-67120748
Fax: 0086-512-6712 0747
Email: info@jc-ebike.com
Http://www.jc-ebike.com
公司地址:苏州市广济南路146号南兵营大厦306室
Address: Room 306, South Barracks Mansion, Guangji South Street 146#
苏州捷诚科技有限公司
