Over time the body adjusts it's muscle strength to match what the weight requires in any given context, so in the longer term one's weight loss or gain makes no difference when the weight is within the normal range.
If you've lost the weight fairly quickly you will notice the gain only short term. If your previous weight was outside the normal range, for example verging on obese, the gain you notice will be permanent.
