Is a removeable motor possible?
Nixtoo
103
47
id really like to convert my second bike but be able to put it back easily. My original has a gsm mid drive which is fab (most of the time).
If I went for a front hub motor could I swap the wheel for a non motorised one easily?
17,234
yes, it's a 15 minute job if it's my XF07 kit..
you loosen the axle bolts, unplug the motor cable, put the old wheel back on.
To remove the battery, undo the 3 M5 allen bolts and unplug the data cable, the pedal sensor and the speed sensor.
grazie
65
nr Canterbury, UK
The most elegant/easy solution is the Copenhagen Wheel, in case you didn't already know about it, but it's quite heavy and costly.
Nixtoo
103
47
The Copenhagen wheels is very pricey, it wouldn’t be easy to remove as the chain length would need to be altered and shifters removed?
Nixtoo
103
47
Thanks for the replies. I’m now thinking a front hub would probably be the easiest option as I could change the wheel back over.
I’m thinking I will need to build the wheel (or have it built) as it’s 27.5”.
I want it to be road legal so a 250w motor. There seem to be loads on eBay but all built into wheels (mainly 26”). Can anyone recommend somewhere I could buy a (cheapish) light weight front hub motor?
5,786
17,234
although the risk of failures in the hub kits is lower than crank motors,.a plug and play system where each functional block can be easily replaced should still be a worthwhile consideration. Such as (in order of decreasing risk): pedal sensor, brake sensors, speed sensor, LCD, controller, motor wheel. When you put for example a controller inside the motor, you actually increase the failure risk of the controller (because of higher ambient temperature) on top of losing the easy replacement feature.
Nixtoo
103
47
Very cheap and they give excellent support.
The price is good. Forgot to get them to add a speed sensor, but they can do brake sensors instead of levers.
They’ve quoted for a sensor and a sensorless controller, which one would be best?
Definitely the sensored motor with the KT controller.
Nixtoo
103
47
These are the options she sent
Price:
YTW-06------------75USD
Sensorless Controller------25USD
Sensores Controller-------25USD
Display-----------------------25USD
Pedal Sensor----------------3USD
Throttle---------------------------5USD
Brake Levers-------------------5USD
Brake sensors-----------------6USD
My knowledge level is not high, only built one bike and converted another. I do like learning though. Are there two versions of the YTW-06? One with sensors and one without? I assume if so the one with sensors would be quieter etc.
Yes. Two versions. The sensorless one is still pretty smooth and quiet, but you get an annoying delay from the controller while it tries to work out the position of the motor before it gives power, and you get a crappy Li Shui controller.
17,234
Lishui controllers are best!
If you check the technical questions on the forum, virtually no Lishui, 99% KT.
Why? You don't have silly things like 15 exposed registers to mess with.
Nixtoo
103
47
I’m hoping it’s all fairly plug and play, with maybe a bit of cable shortening needed?
Nixtoo
103
47
Can the controller be hidden in the battery box (rack battery)? My current mid drive has an inbuild controller.
The xiondga looks like it may be a safer buy than the keyde, but would leave me with a controller to mount somewhere.
The bike is a Marin Stinson step through, so not many good attachment points.
