Kalkhoff agattu clacking noise
lordvincent
69
27
34
I have a clacking sound from the crank/chain area but might be from the rear hub. It sounds exactly like that described on a thread here, which I was reading a while ago, which turned out to be the motor mounting bolts..there was talk of loosening the bolts then jiggling and retightening..but I can't now find that thread!
Does anyone know the thread I'm talking about..or recognise the issue? I would like to know which bolts to loosen and retighten if possible.
30,822
Here's a photo of a bike frame and unit upside down, the three bolt holes arrowed. Tighten those three bolts, they have to be very tight.
This is with the Panasonic unit, but there will be similar bolts for the Impulse units:
Reactions: lordvincent
RobF
4,732
2,312
A skipping chain can also give a clacking noise.
8,760
:eek:From your description sounds like you may have a goose stuck in there some where :D.
lordvincent
69
27
34
Thanks to all. It wasn't any of the threads which shemozzle referenced, but I will tighten the bolts as per flecc's image - looks like I will need a crank puller and some circlip pliers. I will do this and report back as to whether this cooks the goose..
VictoryV
310
208
79
near Biggleswade
Also look for loose golden eggs whilst you are at it
lordvincent
69
27
34
As an update for anyone who may find themselves with the same noise/issue, I tightened the bolts, but unfortunately I overdid it and broke the bolt (I thought it was an M10 for some reason). So having replaced all bolts and the chain and chain wheel, there is still an occasional clack but I'm pretty sure its something to do with the chain as it occurs much less when the chain is properly tensioned.
In any case I'm much less bothered by it now
