I have a bike with a KT controller and LCD4 display, 250W 36V Rear hub motor, it works well enough.
I want the throttle setup so that the throttle is only active when the pedals are moving, with the exception that the the throttle is always active up to 6KM/h for assisted getaways from stationary. The LCD4 manual suggests that this is possible;
The only way I can get it close to working is with P4 = 0, C4 = 4, which to me at least does not make sense according to the manwel. However, although the throttle works at startup and then cuts out, its not at 6KM/h, more like 10+KM/h and its different on each of the bikes.
Any ideas ?
Any ideas ?
