Kt-lcd3 display
5,785
KT LCD3 works with KT controllers. Even then you can have plug mismatches as I did.
Parsons
193
13
50
I thought most LCD display were the same 5 wires just needed to swap the wires around to configure
with your controller .so I need a kt controller
8,230
Controllers and lcd's usually have to be matched (same make) as they use differing software/comms protocols, odd makes may work to a degree but you will not get all of the features to work it at all
Makers/ designers aren't that helpful and don't use a standard universal one fits all software programming for LCDs or controllers.
Parsons
193
13
50
thanks for the reply guys Has I have knackered the display might just stick with the one I got with the controller for now . the kt-lcd3 still works but need to hold you finger on the power button as soon as you let go it goes off. Did a bit of research on the internet some saying that the microprocessor mighty blow
