We experienced the first cut-out from our Ping LiFePO4 yesterday. It happened near the top of a long, slow hill (half a mile, perhaps 1 in 12). My wife was riding with the throttle fully open and the power faltered, then cut out. The battery was about half discharged, and we'd just had a lunch stop for about an hour, so the cells could have re-balanced, which may or may not have been a factor.
The battery regained power after a few seconds, and was fine thereafter.
I've done a few searches on here and elsewhere and it sounds like LiFePO4 cuts out much less than other chemistries. However my new controller is rated 18A (vs 15 for the original Tongxin) so the current drain may be quite high for a 10Ah battery.
I understand there are two things that could be happening. Either;
1. the sustained load leads to voltage drop below the controllers low voltage cut-off - as with the Ezee batteries of a year or two ago. This is what I first thought was happening but now think it's unlikely
2. the load leads to the BMS cutting out to protect an individual cell which displayed a drop in voltage. I think this is most likely.
I'm keen to work out what is going on, as I'm likely to buy a second battery for this bike soon, to increase the range. So, is there any way that these cut-outs can be prevented? Would backing off the throttle on hills (perhaps only having it 80% open) do the trick? Would it be less likely to happen with a higher capacity battery? Or is the set-up likely to keep doing this because of its power requirement or otherwise?
Frank
Frank
