Looking for tips about hub conversion kit
dstryrmnd
Mar 12, 2021
Hi there folks!
Looking for a conversion kit for my bicycle (Specialized FSR XC). I had a thought about a Voilamart rear wheel conversion, but after a bit of research I'm not entirely sure if it's good or not. Are there some other variant in around 200-250 GBP that would work PAS only with hydraulic brake sensor?? ( i assume that the sensor is just matter of wiring up instead of the brake levers ) Also i don't need the throttle because its required to have insurance for it. I would appreciate any suggestions and links if possible!
8,773
Cheap kits use speed control and are pretty rubbish, one gets max current in each pas level so one may as well just leave it max assist anyway. The other levels only differ by max speed assist.
If you want a more user freindly kit one has find a current control controller kit or buy a kt kit.
