Lubricating plastic
camerart
140
9
Dorset
Hi,
I'm looking for a grease to use on a car window winder mechanism, that has nylon parts, and comes in contact with water and dust, so I looked for silicon grease. One thing led to another, and I looked at electrical switches with plastic components, electric bike power gears etc.
I've received a reply from a PTFE dry chain lubricant manufacturer, that this will dry out and isn't perfect, but will do no damage to the plastic. some of these products have a short shelf life, so not suitable to be left 'out of sight and mind'
Does anyone have a suggestion for a general grease, which is economic to buy as a standby, please?
Cheers, Camerart
3,994
Silicone grease. You can't use oil-based greases because they get absorbed by the nylon, which makes it swell and jam.
awol
1,216
374
I think this grease should be ok, it is mineral based and can used around rubber/plastics (but being white might stain?). I've read somewhere a reviewer uses it in his bafang motor with plastic gears without problems.
The last Q&A has a link to the datasheet.
Deleted member 25121
It's based on mineral oil so I wouldn't use it on plastic parts, I suggest using silicone grease which is almost certainly what the manufacturer used.
awol
1,216
374
Just stumbled across this which is the silicone type grease as recommended above and states it is suitable for plastics/rubber.
30,787
Water isn't a problem since it's actually an excellent lubricant for nylon. Just a pity it won't stay in place without containment of course, so silicone grease is the compromise as others have said.
camerart
140
9
Dorset
Hi,
I've ordered some silicon grease.
As mentioned in my initial question, I tried PTFE dry chain lubricant. I contacted 'Muck off' the supplier, and was told, that there is no problem with it, but silicon is correct.
Thanks, to all.
C.
