That will do......I will cycle down to maplins mid weekIf you have a local maplins this is a great little meter, I use one myself.
UT30B Palm Sized Digital Multimeter : Tools & Appliances : Maplin
Your using the AC setting? For DC use the V in the upper half of the dial, it has what looks like a broken/solid equal sign beside it, use range above expected reading For 36v use 200.well I bought the maplins UM 30 even though it says battery required when I opened it it had one. so the battery's are approx £3 so the meter £3.50 how do they do it........
now settings: rightly or wrongly I tried the V~ 200? and on the 9v battery meter read 20 volts. I tried the wisper battery and it read 80 volts. so it seems like meter is doubling up, or I am on the wrong setting any ideas please!
a bike battery should read 42 volts when full? and what when empty?
Sorry about the PM, never think of looking there.Doh!...funny I tried the other settings working OK now, new 9V battery reading 9.6 v E bike not fully charged 38v so all OK now
I will charge it up and see then...so it should read 42 v?
Onmebike, I did PM you regards this, to try and avoid such public humiliation
