More GSM advice please.
Nixtoo
103
47
hi,
The lock rings came loose today, I've tightened them, but noticed there's a slight clicking coming from the pedals. Any suggestions of what I should check? Otherwises it's running really well!
trex
7,703
2,671
jnny6168
21
57
I have just ordered a set aswell as my left hand one kept coming loose and I ended up ordering a crank arm aswell as it got damaged. so pleased you came up with a solution
other than that happy with the kit
jnny6168
21
57
thanks trex I have ordered a set
one thing may be of interest to anyone else I had a noise start from inside harder to pedal.
I took the cover off and found the cog with the cir clip on was bone dry and needle bearings were sticking bit of freeing up and grease on shaft now differant totally to ride so quiet better than new
Reactions: trex
EmSeeDee
69
27
Coventry, UK
the left allen crank bolt tends to get loosened and causes an audible click when the left crank is at 9 o'clock because of the torsion through the BB.
If it's the case, instead of tightening it further, replacing the allen crank bolts with M8 crank bolts will sort it.
http://www.ebay.co.uk/itm/Pair-of-Crank-Bolts-for-Square-Taper-Bottom-Bracket-M8-/262344323019
After doing some googling, I came to the conclusion that the correct torque wrench setting for the crank bolts (the ones that hold the crank arms to the bottom bracket spindle) was 40 Nm. Since tightening mine to that figure, I've had no more problems with them coming loose.
HTH
Mike
Reactions: trex
