Help! My next project
8,827
03 Hall error will either be a wire fault or Hall failure . Test the Halls with a meter to see.
Benjahmin
2,763
1,809
71
West Wales
Just looked up the GrinTech test instructions, I'll give it a go.
This is what I got:
R-Bla 4.3v constant
W-Bla 5v constant
Bla-Blu
Bla-G
Bla-yel All switching 5v-0v
Couldn't get 03 error to come up whilst on the stand. Tried powering the wheel under a braking load but no error.
Benjahmin
2,763
1,809
71
West Wales
Got my new motor, 36v 201rpm, built into wheel and given initial test today.
This motor is much happier on hill climbing. Just did a fairly long, gradually steepening climb on full power. A lot torquier than the last one.
Stopped at the top of the hill to check controller temperature, it felt cool.
Speed registration when pedalling is now pretty much spot on.
However it is still registering 4-5mph low when coasting downhill. This I could live with.
BUT there is still this problem. After a descent, when coming back onto power, it will only deliver around 150w for an unspecific period. I have no idea what eventually triggers it into full action. As there are many V bottomed valleys around here, I need to get this one sorted.
Here are the current settings
P1=168 This assumes 16 magnets and uses quoted reductuin ratio of 10.5
P2=0
P3=1
P4=1
P5=13
C1=07
C2=0
C3=8
C4=3
C5=09
C6=3
C7=0
C8=0
C9=0
C10=n
C11=0
C12=4
C13=0
C14=2
Any idea's anyone?
4,162
P2=0
P3=1
P4=1
P5=13
C1=07
C2=0
C3=8
C4=3
C5=09
C6=3
C7=0
C8=0
C9=0
C10=n
C11=0
C12=4
C13=0
C14=2
Any idea's anyone?
P2 should be 1 or 6, not zero. That should sort out your speed reading as long as you have a working speed sensor.
Reactions: harrys
Benjahmin
2,763
1,809
71
West Wales
I'll try on next ride.
On the stand 6 seemed to be giving an odd reading. I fitted an external sensor that I bought with the motor. I couldn't get any reading from it on any setting. May have been too much space between wheel magnet and sensor.
Zero seemed to give the best.
It's this power delivery delay that's the real problem.
Sparksandbangs
311
129
I think that when you pedal hard past the speed limit the controller decides that it has massively overshot the setpoint and then over compensates by reducing the power for a period.
I don't think that changing the settings will make the blindest bit off difference because it is hard coded in there.
I'm currently experimenting with modifying a Lishui controller to behave like the KT. The hope is that it will get rid of this particular problem and also be more adaptable. It is working on a bench test but I haven't had the time to install it and do a road test.
Reactions: AntonyC
AntonyC
418
173
Surrey
Maybe brake to reach the dip ghost pedalling at 14mph so that the controller's all set for the climb? On mine brake cutoffs respond faster than PAS or speed limit. *
WLT hear more.
* doh, there was a similar suggestion 90 posts ago.
Sparksandbangs
311
129
WLT hear more.
I'm keeping notes. When (and if) I get it fitted I will start a thread.
4,162
Have you still got the white wire on the motor connected to the white on the controller or did you hijack it for the external sensor?
Let me explain how that setting works. if you have a speed sensor, you set P2 =1, or 6 if your motor has 6 magnets in the hub for its internal speed sensor. I've never seen an AKM with 6 magnets, though they could always change for some reason. If you have no speed sensor, you set C2=0, then it'll use the motor halls for the speed signal, but that shows the motor speed, not the bike speed. When you freewheel or have the motor switched off, the speed should show zero, though the motor will still be spinning at its max speed when you go downhill if the power is still on, so that's the speed you'll see on the LCD, not the bike speed.
If your external speed sensor is all wired up, you set P2=1 and adjust the gap to 1mm so that it works, then you get the correct speed at all times, assuming that you've set the correct wheel size.
Even if P2 is et to 1, the speed signal will still default to the hall sensors if there is no ouput from the speed sensor.
Reactions: Benjahmin
Benjahmin
2,763
1,809
71
West Wales
Back of the net !
Somehow I'd got the info that AKM had 6 magnets.
P2 now set to 1. It's sorted it all. Coasting speed registration now correct. Power pick up also now correct.
Thanks once again Saneagle.
4,162
Back of the net !
That motor is a torque monster. When you upgrade to 48v, it becomes a winch.
Benjahmin
2,763
1,809
71
West Wales
I can confirm this. Been up one of my longer climbs at a surprising speed. Speed registration is now consistant and seems accurate. Power cut off and back in is smooth and subtle.
I do still have one issue, however. On my ride there's a long descent. I reach 30-35mph going down it. The bottom is v shaped. Obviously, as I start to climb, I'm over the cut off and am going through the gears as I'm slowing down. I was down to around 8or9 before the power started to kick in, but it ramps up very slowly, so that by the time it gets to around 350-400w (useful power on steep hill) I'm down to about 6mph. As it reaches full level 5 power speed does pick up.
On another milder descent I reached around 25mph, so was still pedalling. Same thing again, as I hit the rise I was down to about 12 before power started to slowly ramp up.
I can't find what evntually triggers pas to respond. Tried going to zero power then back up to 5. Tried the throttle.
I have two questions.
Could it be anything to do with C14? Not sure what this means:
C14 is the parameters of power-assist tuning setting, with the default value of 2. The
power-assist is between1-4 gear, and it is invalid until P3 equals to 1. The setting range 1-3,
and press (UP) button or (DOWN) button for short to make selection.
C14 parameter definition table:
C14 Value Assist strength of intelligent pedal motor
1 Weak assist strength of motor
2 General assist strength of motor
3 Stronger assist strength of motor
Would setting 3 help?
Could it be because I'm using a 12 magnet one piece sensor? I do have a 10 magnet two piece that I could put on.
Sparksandbangs
311
129
Anecdotal evidence because I haven't tested it thoroughly.
Setting C14 to 3 reduces the occurrence of this behaviour. It also makes it a bit too powerful, so a reduction in C5 is needed.
This behaviour definitely happens with C14 is set to 2.
Setting C14 to 1 doesn't work as advertised. It stays fixed at a set power (say 80W for example) no matter what you set C5 at.
Sparksandbangs
311
129
Benjahmin
2,763
1,809
71
West Wales
That's right, that's the problem. Nothing at all until it decides, in it's own good time (and without apparant pattern), to slowly ramp back in.
3,407
Not knowing anything whatsoever about WTF PLC and other settings on these mysterious hub motored objects, I'm wondering if pedal assist delay has something to do with start angle? WTF WTF PLC setting that would be, I haven't the foggiest. My pedal assist start angle is a very convenient 30° - all so much easier to understand on my Bafang BBS01B mid-drive thank F. I do hope this issue is resolved somehow soon, but this thread has further put me off ever attempting a hub drive conversion.
