I may as well start here, as this is where i finished off.
I have a motor and controller tester, and tested the phase and hall wires, as explained before the Giant Suede has six hall wires, red, black, yellow, blue, orange and pink on the controller and new controller has only five
Coupled up to tester red to red on controller
Black to black ..............
Yellow to yellow ..............
Blue to blue .....................
Green to orange ...............
This would only light up two of the hall lights, so changed blue on tester to the pink on the controller and all three lights lit up and when the wheel was turned they lit up in sequence from left to right as they should.
So blue wire to motor is not being used.
Then tested the phase wires, all three bulbs lit up and flickered brightly when the wheel was turned. So these ok.
Fitted a plastic case for the new controller to the bike so the controller was not underneath the bike, coupled up the battery wires, Pas, throttle, phase, hall wires and LCD 861.
Fitted the battery, tried the throttle no movement.
Spun the peddles to see if the Pas was working no movement.
By the way the Lcd was switched on when trying, when i press the
cur button on the Lcd the front wheel gives a jolt but does not turn, and the power indication on th Lcd shows up by about six dots.
The Lcd has fault indicators , for motor, controller, battery, throttle, power brake and under voltage yet none of these are activated.
Anyone know wh
at to try.
ROB
